Completing your car audio system with Garmin
JL Audio products in a trunk and lit up by blue LEDs.
When you’re on the road, Garmin GPS navigators, dash cams and wireless backup cameras have you covered. If you’re ready to round out your vehicle tech with a premium car audio system, Garmin has a wide range of JL Audio® speakers, subwoofers and amplifiers for every ride.
Keep reading learn more about how JL Audio products from Garmin are engineered on the inside for life on the outside.
Speakers
Speaker technology is a lot more complicated than just pressing play on your favorite song or podcast episode.
When it comes to choosing the right car speakers, there are a few things to consider — including vehicle type and potential speaker locations. Better audio systems employ specialized speakers for bass (woofers), midrange (mids) and treble (tweeters). A JL Audio dealer can help determine the best setup and advise you on whether you need component or coaxial speakers and which sizes can be installed.
JL Audio tweeters are small with domes made from silk or lightweight aluminum that help them to smoothly reproduce high frequencies with wide coverage. Midrange speakers cover the middle of the audible spectrum and are medium in size, allowing them to be placed higher in the vehicle for improved clarity.
Woofers need to be big and robust to generate lots of bass energy, which requires more motion and more power handling. In some cases, when a midrange is not used, a component woofer can also extend into the midrange frequencies, handing off to a tweeter.
With two-way and three-way component systems, you can place each individual part where it makes most sense in your vehicle. Unlike component speakers, a two-way coaxial system combines the tweeter and woofer into a single unit. For an included midrange, check out the three-way coaxial system.
So if you prioritize exceptional sound quality at all listening levels or are interested in car audio competitions, the JL Audio C6 car system or C7 car speakers may be for you. For everyday listening that’s great for long drives and adventures, choose between C2 speakers, C1 speakers or custom-fit speakers built to drop into factory speaker locations in many vehicles.
Amplifier
Once you pick speakers to fit your car, you’ll need an amplifier to make them sound their best. An amplifier makes audio signals stronger so that your speakers can produce powerful, crisp audio.
We offer a wide range of JL Audio amplifiers designed to power one speaker to an entire audio system with multiple speakers and a subwoofer. Your JL Audio dealer can recommend the right combination of amplifiers and channel counts to fit your system’s needs. From multichannel, full-range amplifiers to mono subwoofer and system amplifiers, there is an amplifier for every setup.
Power outputs range from 200 watts to 1500 watts so you can pick the right power for your speakers and system design. When you select our VXi car amplifiers, you also get the benefit of a powerful onboard tuning system built into each amplifier.
Subwoofer
For music to sound real and exciting, it needs a solid low-frequency foundation. The job of a subwoofer is to provide enough bass output to overcome road noise and relieving the smaller speakers in the car from the burden of making bass. This makes the whole system sound cleaner, more powerful and much more fun to listen to. Because of their purpose-built design, JL Audio subwoofers can handle large amounts of power without distorting the sound quality.
JL Audio subwoofers can be installed into custom-built enclosures, from a tiny 6.5” model to the flagship 13.5” W7AE subwoofer. There is a series and a model for just about any power level and enclosure size.
With our enclosed subwoofer systems, such as the StowAway™ or ProWedge™ models, our engineers have done all the work of placing the driver into a well-optimized enclosure. These are available in many sizes and shapes, including some with built-in amplifiers. For vehicles that do not have lots of extra space for a subwoofer enclosure, our Stealthbox® subwoofers are engineered to fit into specific vehicles, without compromising too much space.
Don’t wait to enhance your ride. Enjoy great sound when you select the perfect audio setup for your vehicle.
