What’s the difference between Garmin fēnix 7 and fēnix 8?
Both are premium GPS smartwatches, but new features make fēnix 8 a better choice.
If you’re thinking about buying fēnix® 8, you’ve come to the right place.
You might also be considering a fēnix 7. Before deciding, you need to know about the differences between the new fēnix 8 Series and the fēnix 7 Series of GPS smartwatches.
You already know fēnix is the premium multisport GPS smartwatch. You know it’s the premium adventure watch, thanks to its lengthy battery life and rugged design. You know you can trust it during your outdoor recreation activities.
We’re going to compare the fēnix 8 Series to the fēnix 7 Series so you can choose the best watch for you.
New display options
The fēnix 8 series offers a bright AMOLED display or a solar charging display with a memory-in-pixel (MIP) screen. This means you can choose between a brighter screen or longer battery life.
The fēnix 7 series also has a transflective MIP screen that’s visible in sunlight. It does not have an AMOLED option.
The fēnix 8 – 47 mm AMOLED premium smartwatch also offers a bigger display at 1.4” compared to 1.3” on fēnix 7, as well as a higher resolution with 454 x 454 pixels compared to 260 x 260 pixels.
Improved solar charging
Battery life will vary depending on which version and size you buy, with larger watches offering longer battery life and enhanced solar charging taking your battery even further.
fēnix 8 – 51mm provides 50% more solar power than its predecessor, lasting up to 30 days in smartwatch mode or up to 48 days with solar charging1.
fēnix® 7X Pro – 51 mm, Solar Edition will last up to 28 days in smartwatch mode or up to 37 days with solar charging.
The consensus? The fēnix 8 series battery will last longer.
Upgrades you can’t get on fēnix 7
Make and take phone calls: Thanks to the speaker and microphone, you can pair your fēnix 8 to your phone to make and take phone calls or use your phone’s voice assistant (like Siri) to respond to texts.
Phone-free voice commands: You can also use voice commands — even when you don’t have internet — to control watch functions.
Scuba and apnea dive activities: fēnix 8 supports scuba and apnea dive activities up to 40 metres deep. (Both fēnix 8 and fēnix 7 have a water rating of 10 ATM.)
Dive-rated with leakproof buttons: Built to endure, fēnix 8 has leakproof inductive buttons.
Sensor guard: The new metal sensor guard helps protect essential sensors.
Which should you choose?
fēnix 8 is the latest and greatest in our premium multisport GPS smartwatch lineup. You’ll get two display options, improved battery life, new smart capabilities and durable upgrades that let you dive to another level.
It’s time for you to be limitless. The fēnix® 8 series is ready for you.
1Assumes all-day wear with 3 hours per day outside in 50,000 lux conditions
