Revolutionary Garmin Autoland and Autothrottle receive EASA certification for retrofit installations in select Beechcraft King Air aircraft
Announcement marks first twin-engine certification and retrofit offering of Garmin Autoland in Europe
OLATHE, Kan./March 4, 2025 – Garmin (NYSE: GRMN) today announced European Union Aviation Safety Agency (EASA) approval to bring Garmin Autoland and Garmin Autothrottle to the retrofit market, starting with select G1000® NXi-equipped King Air 200 series aircraft. The King Air 200 was introduced over 50 years ago, and this certification marks the first time Garmin Autoland and Autothrottle have been offered to European owners and operators as a retrofit solution. Full Autothrottle integration with the G1000 NXi reduces crew workload in the cockpit by managing aircraft speed and power and provides engine protection against potential engine exceedances. In the event of an emergency where the crew can no longer perform their duties, Garmin Autoland can control and land the aircraft without human intervention.1
Preview Garmin Autoland in the King Air here. Preview Garmin Autothrottle in the King Air here.
Garmin Autothrottle
Garmin’s Autothrottle, offered as a retrofit solution in the King Air, provides extensive safety-enhancing features and can greatly reduce workload in the busy King Air cockpit. Autothrottle is fully integrated with the G1000 NXi system and provides automatic control of the engine power levers from takeoff to landing. Autothrottle keeps power levers in the proper power setting, minimizing the threat of a possible throttle rollback. Power settings are based on manufacturer or user-configurable climb, cruise, and descent schedules, including ITT limits. Additionally, Garmin Autothrottle provides ITT and torque protection by reducing power when the system senses potential overtemperature or overtorque conditions.
Autothrottle will also activate automatically in the event of an aircraft overspeed or underspeed situation and takes into account flap and gear position, providing additional peace of mind for pilots operating the aircraft. If Autothrottle detects an engine failure, it automatically sets the power lever on the failed side to a fixed position and adjusts the operative throttle lever to maintain the selected airspeed reference.
Garmin Autoland
With family, friends or business colleagues on board, a pilot’s top priority is keeping everyone safe. Now there is a way to provide even more passenger reassurance in this popular aircraft: the award-winning Garmin Autoland system. Autoland determines the most optimal airport and runway, considering factors such as weather, fuel on board, runway surface and length, terrain, obstacles and more. In the event of an emergency, passengers can activate Autoland with the press of a button, located in the back of the center pedestal for easy access. Autoland will activate automatically if the system determines it’s necessary.
Once activated, the system calculates a flight path to the most suitable airport, initiates an approach to the runway and automatically lands the aircraft. The system takes into consideration a breadth of information and criteria and will automatically communicate with air traffic control (ATC) throughout the entire event, advising controllers and pilots operating near the aircraft of its location and intentions.
Throughout an Autoland activation, the system provides simple visual and verbal communications in plain language, so passengers have the information and know what to expect. The flight displays show the aircraft’s location on a map alongside information such as the destination airport, estimated time enroute, distance to the destination airport and fuel remaining. Airspeed, altitude and aircraft heading are labeled in an easy-to-understand format and passengers also have the option to communicate with ATC by following instructions on the multi-function display.
At any time, a pilot can easily deactivate Autoland with a single press of the “AP” autopilot key on the autopilot mode controller, or the autopilot disconnect button on the yokes. The flight display shows a message that confirms Autoland has been deactivated and in the event of an accidental deactivation, the system shows passengers how to reactivate Autoland if needed.
During an Autoland activation, the Garmin Autothrottle system is used to automatically manage aircraft speed and engine power so the aircraft can climb, descend or maintain altitude as needed. If temperatures are conducive to ice accumulation, Autoland activates anti-ice and deice systems for the engines and control surfaces. On approach to landing, the system initiates a controlled descent to the airport. If the aircraft needs additional time to descend or slow down during the approach, the Autoland system initiates a standard holding procedure. Once Autoland configures the landing gear and flaps, the aircraft begins its descent to the runway and lands. On the runway, automatic braking is applied while tracking the runway centerline to bring the aircraft to a complete stop. Engine shutdown is also automated so occupants can safely exit the aircraft.
New G1000 NXi Features
With the latest G1000 NXi upgrades, King Air owners can take advantage of additional features. Synthetic Vision Technology (SVT™) has been upgraded to now include a 3D exocentric view of the SafeTaxi® airport environment to aid situational awareness while taxiing. SVT also displays 3D building footprints including hangars, terminals and towers, taxiways, aprons, signs and other markings to help reduce runway incursions by providing guidance while taxiing at airports contained in the SafeTaxi database. These SVT updates also increase topographical clarity, sharpened water and terrain boundaries, improved obstacle and powerlines display, enhanced runway and airport sign depiction and more.
Adding on to Garmin’s revolutionary electronic stability and protection (ESP™) technology, one engine inoperative ESP assists the pilot in maintaining control in the event of a single engine failure. ESP pitch and roll limits will adjust to prevent excessive pitch or bank angles while the pilot performs single engine procedures. The system also includes Emergency Descent Mode (EDM) as a standard feature that is enabled automatically, in the event of a loss in aircraft pressurization.
Garmin Autoland and Autothrottle are now available for retrofit installations through the approved Garmin Authorized Dealer network for King Air 200 G1000 NXi installations. To learn more about the G1000 NXi upgrade and Garmin Autothrottle, visit Garmin.com/KingAir. For additional information about Autoland and the Garmin Autonomí family of autonomous safety-enhancing technologies, visit www.garmin.com/Autonomi.
Garmin products and services have revolutionized flight and become essential to the lives of pilots and aircraft owners and operators around the world. A leading provider of solutions to general aviation, business aviation, rotorcraft, advanced air mobility, government and defense, and commercial air carrier customers, Garmin believes every day is an opportunity to innovate. Recipient of the prestigious Robert J. Collier Trophy for Garmin Autoland, Garmin developed the world’s first certified autonomous system that activates during an emergency to control and land an aircraft without human intervention. Visit the Garmin Newsroom, email our media team, connect with @garminaviation on social, or follow our blog.
1See Garmin.com/ALuse for Autoland system requirements and limitations.
About Garmin International, Inc.
Garmin International Inc. is a subsidiary of Garmin Ltd. (NYSE: GRMN). Garmin Ltd. is incorporated in Switzerland, and its principal subsidiaries are located in the United States, Taiwan and the United Kingdom. Garmin, G1000 and SafeTaxi are registered trademarks and SVT, SurfaceWatch, PlaneSync and ESP are trademarks of Garmin Ltd. or its subsidiaries.
All other brands, product names, company names, trademarks and service marks are the properties of their respective owners. All rights reserved.
Notice on Forward-Looking Statements
This release includes forward-looking statements regarding Garmin Ltd. and its business. Such statements are based on management’s current expectations. The forward-looking events and circumstances discussed in this release may not occur and actual results could differ materially as a result of known and unknown risk factors and uncertainties affecting Garmin, including, but not limited to, the risk factors listed in the Annual Report on Form 10-K for the year ended December 28, 2024, filed by Garmin with the Securities and Exchange Commission (Commission file number 0001-411180). A copy of such Form 10-K is available at http://www.garmin.com/aboutGarmin/invRelations/finReports.html. No forward-looking statement can be guaranteed. Forward-looking statements speak only as of the date on which they are made and Garmin undertakes no obligation to publicly update or revise any forward-looking statement, whether as a result of new information, future events, or otherwise.
Contact
Mikayla Minnick
Phone | 913-397-8200
E-Mail | [email protected]
Public Company Information
NYSE: GRMN
