Garmin aviation smartwatches: Tools for flying — and more
Pilots have long relied on timepieces that are accurate, easy to read and built for the demands of flight. While the tools in the cockpit have evolved dramatically over the past century, a trusted watch remains essential for flight.
Garmin has built on this tradition by creating smartwatches purpose-built for flying — each tailored to your desires and budget. All can help show your pride in your pilot lifestyle, with vivid displays and iconic aviation-themed designs, but they’re way more than just stylish. Our aviation watches have advanced tools for flying, health and fitness, and connectivity right on your wrist.
Here are five ways our aviation smartwatches with GPS can support you in the air and beyond.
1. Weather at your fingertips
Foremost, an aviation watch can assist a pilot in executing a safe flight. That starts with planning. With Garmin aviation watches, you can access up-to-date weather reports, including METARs and TAFs for airport conditions such as winds, visibility, barometric pressure and more1.
Our D2™ Mach 2 series and D2 Air X15 series can even display METAR information right on the watch face, along with a UTC pointer and 24-hour clock around the bezel. And for even greater situational awareness, both the D2 Mach 2 series and our luxury MARQ® Aviator series smartwatches display NEXRAD radar overlaid on a full-color moving map and color-coded METAR flags indicating the current conditions for each airport1.
Configurable for nearest airport and more airports, the D2 Mach 2 monitors weather conditions against their own personal minimums and sends alerts when a threshold is crossed. The watch face can display the weather elements in orange if the selected airport’s METAR reports conditions that exceed the user-configured personal minimums.
2. Navigate from your wrist
As a pilot, you know the importance of having a Plan B, Plan C or even Plan D. With our aviation smartwatches, you have backup navigation on your wrist to keep you on course.
Fly Direct-to a location or waypoint in the built-in worldwide aeronautical database — or choose the Nearest function to activate a path to a nearby airport. An instrument-like HSI course needle helps you see if you’re left or right of your desired flight path easily, while en route details such as distance, ETE and flight time ensure you’re prepared as you approach your destination.
With the D2 Mach 2 and D2 Air X15, and when connected to the Garmin Pilot™ app2, you can connect to compatible avionics to display flight and navigation information. The D2 watches also notify the user of crew alerting messages from compatible avionics right on the wrist1.
Let’s not overlook the unsung heroes in our D2 Mach 2 and D2 Air X15 — the LED flashlight and PlaneSync™ compatibility. The built-in LED flashlight features multiple white light intensities and a red light for nighttime flight operations.
Those operating a PlaneSync-equipped aircraft can access the dashboard to view status information3 including fuel, electrical, database and location while away from the aircraft.
Whichever Garmin aviation watch you choose, you’ll have peace of mind knowing you have a reliable navigation backup at hand.
3. Stay aware at altitude
Flying at higher altitudes affects not only your aircraft but also your body. Garmin aviation watches help you stay aware of both. Use Pulse Ox4 to monitor how well your body’s oxygen level is adjusting to the thinner air at higher altitudes, and rely on the barometric altimeter to confirm when you’ve reached your desired altitude. You can even set vibration alerts to inform you when you’ve reached an altitude where supplemental oxygen may be required. Custom alerts can also be programmed to remind you of time-critical tasks such as switching fuel tanks.
To make recordkeeping easier, our D2 aviation smartwatches can automatically log your flights and sync them to the Garmin Pilot app, then transfer flight details — including date, duration, total flight time and route — to your flyGarmin.com® account1 for easier currency tracking and logging.
4. Make time for fitness
Flying demands focus. And staying healthy helps you bring your best to every flight. Our aviation smartwatches include wellness and fitness tools to keep you in top form between trips. With the Health Snapshot™ feature, you can capture key data such as heart rate4, heart rate variability5, Pulse Ox4, respiration and stress.
See your body’s energy levels so you can find the best times for activity and rest, while advanced sleep tracking and sleep score insights help you recover more effectively. Plus, with preloaded profiles, including trail running, swimming, running, biking, hiking and more, you can track almost any workout.
And the advantages don’t stop there. With excellent battery life, you can keep a continuous view of your health to support your fitness goals and flying readiness. From the air to the water, the D2 Mach 2 watch has built-in support for recreational diving and scuba activities.
5. Stay connected from anywhere
Garmin smartwatches also help you stay connected on the ground and in the air. Receive emails, texts and alerts right on your watch when paired with your smartphone. D2 Mach 2 and D2 Air X15 both allow you to make calls from your wrist, plus create or respond to text messages hands-free, courtesy of your paired smartphone’s voice assistant.
You can also download songs and playlists from your Spotify®, Deezer or Amazon Music accounts (subscription may be required) and use your wireless headphones for phone-free listening. Plus, you can breeze through checkout lines and select transit systems with the Garmin Pay™ contactless payment solution through participating providers. Whether it’s staying in touch, staying entertained or just getting through your day more efficiently, these features make your watch useful beyond the cockpit.
The D2 Mach 2 and D2 Air X15 also provide a daily feature where users receive a personalized aviation morning report for visibility into the day’s weather outlook and conditions at their current location. Plus, D2 users can enjoy voice notes — good for that reminder to look at something when back on the ground — and two-way text messaging directly on the wrist, via the Garmin Messenger™ app6.
With a modern, impressive set of features, our aviation smartwatches are designed to keep you informed, prepared and connected. From preflight planning to en route awareness, to tracking your health and staying in touch, they bring powerful capabilities to a pilot’s wrist. Quite simply, these watches not only help you fly smarter, but live better, too.
1When paired with a smartphone, with a data connection, and in range of Bluetooth® technology
2Receiving avionics alerts and position data requires the Garmin Pilot app for Apple® mobile devices
3Remote aircraft status requires active PlaneSync subscription. User’s smart device must have internet connectivity. Feature is available on-ground only and requires GDL 60 to have LTE connectivity; signal strength and other factors may apply. See Garmin.com/PlaneSyncCoverage for coverage details.
4This is not a medical device and is not intended for use in the diagnosis or monitoring of any medical condition; see Garmin.com/ataccuracy. Pulse Ox not available in all countries.
5Activity tracking accuracy
6Requires both the send and receiver of messages to have the Garmin Messenger app installed on their paired smartphones
Apple is a trademark of Apple Inc., registered in the U.S. and other countries.
SPOTIFY and the Spotify logo are among the registered trademarks of Spotify AB.
Amazon Music and all related logos are trademarks of Amazon.com, Inc. or its affiliates.
The Bluetooth word mark and logos are registered trademarks owned by Bluetooth SIG, Inc. and any use of such marks by Garmin is under license.
